I suggest uploading your gcode as well,
Two test files (10mm high, 5mm dia cylinder. With & without gcode mods.
your copy of pause at height, and also let know (and confirm) what you put the pause layer height at.
The "pauseAtHight" script is whatever is distributed with Cura2.4! And this is the GUI:
All that happens is that a comment (;POSTPROCESSED) is inserted at line 5.
Regards, Martin
Kin 3
I suggest uploading your gcode as well, your copy of pause at height, and also let know (and confirm) what you put the pause layer height at.
I suspect it's just that you are attempting to pause above a layer that the gcode gets to, as a typo or something.
