Simplify3D retraction bug that can drive you nuts :)
neotko
Posted (edited) · Simplify3D retraction bug that can drive you nuts :)
This is bug that has been quite weird, but I think some users on S3D forum reported it, year ago, and still is unfixed and seems noone explained why or how to reproduce it.
So, here I go =)
When using multiple processes S3D thinks of each process as a new print, and their planner aligns them so they print 'right'. The problem with this is that he also thinks that when moving from process A to B the tool is different, so, he does a Tool Retraction Distance if you have wipe at the end of a loop, or Z change... Well, mostly, it does it correctly, but it forces a very very long retraction, that can end up adding blobs (because the head stays retracting more time) or it could, on Full Metal hotends, to clog.
So... If you use one hotend, just change the Tool Change to 0, distance 0, but don't touch the speed (or set is as the same your main settings use)
But if you use Two or more hotends, you will need to make your own toolchange retraction distance on the toolchange script area (not hard at all).
So to show my point, I just made made two prints one with this
5a33285b3880e_Capturadepantalla2017-03-16alas0_56_11.thumb.png.378817d4b8746ca21143773445e91231.png
And other with the values set to 0 (again, except the speed)
And as you can see, the retraction bug disappears
5a33285b4cdc0_Capturadepantalla2017-03-16alas0_58_25.thumb.png.9697011772c91f0330a7b62237ccd981.png
So, if you use S3D multiple process, and a single hotend, or two, and you want to enjoy the wonders of wipe, coasting, retract-while-wipe, etc.. You NEED to set the toolchange distance to 0 and if you use multiple hotends, make your own E- script for the tool change.
And, why this is important btw? Because the bug makes the whole print slower, and full of weird retraction distances. Check this Gcode compare, Left is bad, Right is ok. For Full metal hotend users, this is a very important thing to check.
5a33285b67755_Capturadepantalla2017-03-16alas0_58_49.thumb.png.042494914ebd0ef36dd28ebbef47751a.png
  • Like 3
Posted · Simplify3D retraction bug that can drive you nuts :)
Do I understand you correctly?, only with activated setting "Perform retraction during wipe movement" occurs the bug!
Wipe also, is a problem of moving from one process to other. Coasting also too. Without perform retract during wipe it can also happen with retract while changing Z.
    • 1 year later...
    Dude :|
    Dont get me started on retraction problems.
    Every damn software i tried to this very day has it.
    Its either retracting or not retracting when you expect it.
    I am assuming its because people who designed these software have crappy extruders that are not capable of handling lots of extrusions like my extruder does.
    CURA
    CRAFTWARE
    REPETIER
    Simplify3D a $150 or what ? *|
    Kissliser
    Slicer
    Matter Control (a joke that uses OTHER slicer engines such as CURA and REPETIER because its own is garbage)
    SliceCrafter (has no retraction option whats so ever)
    just to name a few i tried.
    I am tired of this. Wish i could program my own.
