I think your first layer is yoo thin (less than 0.2) and the nozzle is a bit too close to the bed. Readjust the bed knobs onthe fly while printing the first layer.
I'm not very familiar with this issue but other's have said this is a problem for certain filament colors and manufacturers. Have you tried a different color or brand filament? Is this white filament? Or Gray? I have the most trouble with white filament (all manufacturers). I think white filament has a high amount of talc in it - not sure.
Yes it is white filament, on previous grey PLA filaments it did not happen or it was a very tiny spot here and there.
The Layer height is set to 0.2mm and initial layer height is set to 0.27mm
I think Neotko meant you should adjust the height of your glass bed a tiny amount. The three screws that adjust the bed height are 0.5mm per full rotation. Try rotating all 3 of them CW 1/3 turn to move the bed down by 0.1666m.
Even better, try turning them that much while it's printing the bottom layer and you should see instant results and learn from that and iterate.
neotko is very smart and has done more prints maybe than anyone on the forum. He has several printers going all week long, all year long.
1
gr5 1,871
