I am printing in stand-alone mode from the ulticontroller as this one sits in my basement with no computer in sight. Power is fed from a dedicate 24V - 400W supply. Both the nozzle heater and heated bed are using PID control. I noticed the LED on the headed bed continued to flash even after the stoppage. I'm inclined to say that at least the Arduino and main circuit board were still functional enough to provide the PID signal to the heated bed. It is suspect that this happened right as the transition from the second to third part. So, I'm thinking something in the gcode (Cura) or the ulticontroller had an issue.
In this room, there are not any other running electrical devices as I unplug everything when it isn't in use and the light was coming through the windows.
John
gr5 2,071
I found the usb cable to be unreliable and only print using ulticontroller and SD card option now. However if you don't want to buy a UC then try to limit noise maybe? No AC fan's or microwaves ovens or hair dryers in the house while printing?
It often crashes right at the start or end of the print job (have to reconnect with cura when it crashes). Maybe something is causing a voltage spike then (turning on or off the heater causes noise spike?) so it makes sense to me this would happen part way through the print job but right at the end of a part (or start of the next).
