And also, PauseAtHeight is broken in 2.4....
(see https://github.com/nallath/PostProcessingPlugin/issues/38 )
thanks for the quick answer. Turned out it works, but only for bigger prints and a pause hight higher than 3 mm.
Marco_TvM 34
This will be fixed with the 3.6 version of the Firmware on the printer.
This release can be found as the testing release if you want to try it out.
Also, it's expected for the release of the 3.6 version of the Firmware to happen this week.
Edited by Guest*indication of 3.6 release added
