The best settings are made default in Cura. Use Cura 2.4 for the best result.
If you don't have good results with these settings (for Ultimaker PVA), you must not look for settings to solve your problems, but you must look to the hardware.
When PVA is concerned, chances are your print core is (partly) clogged. This causes underextrusion, and that may cause something that looks like layers not sticking together.
Use the instructions on the UM website to clean your BB core.
tomnagel 126
