But there is a setting for the first layer temp in Cura.
If i set this
M140 S{material_bed_temperature} T0 ; Heat buildplateM134 T0 ; Stabilize bed temperatureM104 S{material_print_temperature} T0 ; Heat right extruderM133 T0 ; Stabilize right extruder temperature
the printer is heating to print temp and not the set first layer temp.
ultiarjan 1,223
The g-code is the same, it's just the position where it's placed..... there is no specific "first layer temp" code afaik
