Yep that did the trick.
Thanks
The "Wall Thickness" setting got disabled because it was overridden by the value you entered in "Wall Line Count". Just because you hid the "Wall Line Count", it does not mean this value has gone away (it is like sweeping the value under the carpet; it is still there).
If you press the "revert arrow", this removes the absolute value and reverts back to the value that is calculated from the "parent" setting.
To make you understand, keep both the "Wall Line Count" and the "Wall Thickness" visible. Now change the "Wall Thickness" value and you should see the "Wall Line Count" value update automatically. The latter is calculated from the former.
When there are nested settings, CuraEngine always only uses the last setting in the branch. The parent settings are mostly convenience settings; it is often easier to think in millimeters than in the number of perimeters and calculate that back from the line width.
Thanks
I know it had to something simple
Rocket Nut
Labern 772
If you turn the visibility of Wall Count back on then click on the curved arrow. this will reset it back to default and should work again.
.thumb.png.c9fd332e6dfd739d0b0256c6da47d7f9.png)
Edited by GuestLink to post
