UM3 camera
Gigi
Posted · UM3 camera
When printing is ok, the corner of the buildplate you see in camera view is not moving. But when something is going wrong wou will see a movement up and down because the printhead is pushing on the print.
    • 3 weeks later...
    Posted · UM3 camera
    It is about first few layers when printing.
    For example if the print will start rise from the bed.
    It did happened to me and i cancel the print saving 5 hours.
    Just a small question, which version of the firmware, on the printer, are you using?
    Posted · UM3 camera
    3.6
    Problem was with a chassis of an railroad model locomotive 18 cm long.
    At one end printed part raised from buildplate.
