There is a short axis??
Actually, there's a shorter axis on the Ultimakers, like half a tooth of a GT2. First time I see someone else notices this
Also @jackieshaq UMO+ has one of the worst (IMHO, and others) set of pulleys. If you are serious about printing better, the best and first thing you should do is move to GT2 belt
https://ultimaker.com/en/community/15874-mxl-vs-gt2-print-results
gr5 1,872
Short belt?
There are several issues that can create parts that are not accurate:
- PLA shrinks about .3%
- PLA can stretch and move inward mostly near the bottom 2mm and also all vertical holes are affected big time
- axis not perpendicular/orthogonal
- bottom layer sticks out too much
- play/backlash
This is not complete but it is by far covers the worst issues.
I think you are talking about backlash but if you could photograph your part and explain what dimensions are off and by how much most people can instantly diagnose the issue.
Edited by GuestLink to post
