Yes, But i speeded up the print a little bit...
I think, it's an mechanical problem
Could be a bad temperature sensor which reports false readings and the heater does not heat up the nozzle properly. The pattern on the vertical walls look somewhat regular which tells me that it is recurring at some point even though it happens on different layers.
Hallo Siebet,
Welke laagdikte heb je geprint met je 0.8mm nozzle?
Which layerheight did you print with your 0.8mm nozzle?
Nicolinux 288
Which Cura version did you use to slice your model? If you used Cura 2.x, did you select the right nozzle size and a profile?
