1) The only cure is a heat gun and a few hours of patience. Or send it back to the manufacturer - who will do the same thing.
Actually, a service technician from our reseller suggested something that worked surprisingly well. Heating up both cores to the maximum temperature possible and carefully pulling the filament out with a pair of tweezers got rid of the problem quickly, at least to the point where we could remove the print cores and swap them for spare ones. I thought I'd share that in case someone else had the same issue.
2) There is supposed to be a silicone pad - a white flexible thing with 2 holes in it for the 2 nozzles. You seem to be missing those maybe? I can't tell in these photos. That is supposed to prevent this exact accident.
We had the pad installed, unfortunately without effect. Our pad didn't look to good though:
[media-thumb=59480]
[/media-thumb]
3) You really need to get your parts to stick to the bed better. You don't want your parts sliding around the bed. Here is a long but full of useful information (I shortened it a lot in editing) video about how to avoid this in the future. Also *ALWAYS* watch the first layer going down - at least the 4 corners - to make sure you are getting good "squish" (again - see the video).
Thank you for the video, appreciate it. We did watch the first layers go down, but I guess they came lose later. I will make sure to see what else we can do to improve adhesion.
gr5 2,210
Oh, Matt - this sucks. A few things:
