kmanstudios 1,099
You could check to see if the printhead cable came a bit loose during the move. What you report is part of the communications error messages.
https://ultimaker.com/en/resources/23154-there-is-a-communication-error-with-the-print-head
This also is something to check with this:
https://ultimaker.com/en/resources/23155-there-is-an-i2c-communication-error
Those two errors are connected.
Unscrew those two screws in the top, back of the printhead out, slide a small screwdriver in those little slots and it will slide right off. With a small instrument, push down on the plastic sides of the cable connector. Mine has come loose when using a lot of heat over time. I am guessing that the heat makes the plastic soft and loosen.
Also, next to a washing machine? Doesn't that throw your humidity levels way up?
ssichab 0
I have the exact same issue with my UM3 since 2 days : it stops after a few hours of printing displaying ER18.
Reading your posts I guess that it may comes from the fact that I just moved my UM3 to the basement( with a washing machine next to it). It may afect the printer power management system (espacially if the UM engineers didn't separate the power circuit from the command circuit in the printer design...).
Do you think that using a UPS could ease the pain ?
Tkx
Laurent
