fbrc8-erin 265
I'd also go ahead and change your brim to PVA, so your PVA is directly on the glass instead of directly on top of the PLA.
Choose Custom instead of Recommended. If you don't have the filter box visible, click the magnifying glass. Type "Build." You should see an option for Build Plate Adhesion. Change from Extruder 1 to Extruder 2 so you can do your brim in PVA. It will improve the adhesion of all the horizontal expansion PVA around the outside of your print.
tomnagel 90
Are you using Cura 2.4 or higher?
From the release notes of 2.4:
Hope that helps you.
Edited by GuestLink to post
