Just to clarify... you need to hold down the upper part of the coupling, while at the same time pulling the tube up and out.
Thanks for that advice.
I tried pushing the PLA through but it ended up being a blob stuck in the hot end.
I followed these instructions: http://wiki.ultimaker.com/Jamming
and it's all working again now.
IRobertI 513
Push down on the topmost part of the coupling and then pull the tube out. Remember to heat up the hotend before pulling out the filament
Or if you want to be lazy simply feed some new PLA in there and keep printing.
