I think this is a "feature" of the UMO/+ feeder. The large wheel, being made out of plywood, is not perfectly flat. However, it is not really a problem if you assemble the feeder with enough "slop".
Make sure you have two flat washers as spacers on the knurled bolt before installing it through the ball bearings in the feeder. If you already have two washers there, make sure that the knurled bolt is protruding far enough away from the large gear. The assembly instructions provide a guideline, but you may need to adjust it by unscrewing the knurled bolt a bit and re-tightening the acorn nut.
It is OK if you have some axial play between the large wheel/gear and the feeder frame. The knurled bolt and gears are wide enough to accommodate quite a bit of misalignment. The important thing is to avoid friction from the large wheel rubbing on the screw heads, which is what I think your problem is.
1
peggyb 171
put a washers in between, I had the same problem.
rowiac 53
