I don't think that infill should look like this...
Tiger91
Posted (edited) · I don't think that infill should look like this...
I've been printing and noticed recently that the infill looks like its kind of weak and scraggly:
https://drive.google.com/file/d/0B3BtcLye8-jzb0lzRnVzbFp0bUU/view?usp=sharing
https://drive.google.com/file/d/0B3BtcLye8-jzWmtfMDUzZ3NDQW8/view?usp=sharing
The strange thing is that's a fairly recent change, it used to have thick, connected infill.
I only changed the infill % in cura, nothing else.  Using PLA mainly, and its still happening after updating Cura to the latest version.  Anyone know what might be happening and how to fix it? I've tried it with both nozzles, and both motors, so I'm pretty sure its an issue with the software.
The outside walls of the prints are fine though.
    Posted · I don't think that infill should look like this...
    I think default profiles infill speed are sometimes a bit high, can you check what infill speed you have? I usually change the infill speed to be similar to the other speeds.
    As I have experimented, I have created that by what DidierKlein says. I have tried to push boundaries to increase speed without sacrificing quality and two things have affected the infill in my tests.
    1. Infill speed
    2. choosing a type of infill that has steps involved (Tetrahedral as an example) and setting them too high.
    Just passing that on and seconding the suggestion.
    1. Infill speed
    Just checked, at default print speed and infill speed is 70 mm/s.
    Everything else is default.
    Default speeds and such are good starting points. But so many things can affect the print quality in areas. Filament changes, environmental changes such as temp and humidity changes.
    Just try cutting back the infill speed. Make sure your infill type is not too thin by way of too large of steps and such (Again, the cubic/tetrahedral thingy). Make a simple cube or two for fast testing and see how the infill starts to change.
