If I tell Cura 2.5 that I'm using an UM2+, the gcode will be correct, no?
No the e-steps is a firmware thing...
(it can be overridden with GCode, but it is not a common practice)
Ok thanks.
zerspaner_gerd 348
Attention, the direction of rotation of the feeder must be changed!
Normally this is done over the firmware update.
1
Good point.
And you cannot change that with G-Code...
You could swap the cables of the stepper, but waiting on a solution for the firmware is probably easier...
Thanks guys, believe it or not I was actually aware of the stepper motor direction issue - however that's what I thought the G-Code mod was for! Clearly not.
OK, so can I safely install the new hot end, but wait until later for the feeder? Everything else, the heaters, the new thermocouple, everything at the hot end of the UM2+ upgrade kit will be OK with firmware Vers:_15.04.5?
Thanks again,
Matt.
Temperature sensor is a PT100 on both version, not a thermocouple.
But yes, you can safely upgrade the hot end and keep the same firmware.
Beg your pardon, temperature sensor.
Thank you both for the advice - as you'll see in the aforementioned thread, the firmware issue is sorted.
Cheers,
Matt.
amedee 348
The feeder needs a different e-step setting.
So you can either stay with the old feeder until your firmware issue is solved, or add a
in your GCode to adjust the e-steps manually
