Can I safely upgrade my UM2 to UM2+, and use Cura 2.5, but with firmware Vers:_15.04.5?
purps
Posted (edited) · Can I safely upgrade my UM2 to UM2+, and use Cura 2.5, but with firmware Vers:_15.04.5?
As the title says really! I would appreciate any and all help.
Discussion of my firmware upgrade problems is here https://ultimaker.com/en/community/44827-cant-update-firmware-on-um2-i-think-ive-checked-all-the-obvious-stuff
Obviously that problem needs solving, but in the short term I need to crack on as I have orders to fulfill.
Cheers,
Matt.
    Posted · Can I safely upgrade my UM2 to UM2+, and use Cura 2.5, but with firmware Vers:_15.04.5?
    The feeder needs a different e-step setting.
    So you can either stay with the old feeder until your firmware issue is solved, or add a
    M92  E369.00
    in your GCode to adjust the e-steps manually
    No the e-steps is a firmware thing...
    (it can be overridden with GCode, but it is not a common practice)
    Attention, the direction of rotation of the feeder must be changed!
    Normally this is done over the firmware update.
    Good point.
    And you cannot change that with G-Code...
    You could swap the cables of the stepper, but waiting on a solution for the firmware is probably easier...
    Thanks guys, believe it or not I was actually aware of the stepper motor direction issue - however that's what I thought the G-Code mod was for! Clearly not.
    OK, so can I safely install the new hot end, but wait until later for the feeder? Everything else, the heaters, the new thermocouple, everything at the hot end of the UM2+ upgrade kit will be OK with firmware Vers:_15.04.5?
    Thanks again,
    Matt.
    Temperature sensor is a PT100 on both version, not a thermocouple.
    But yes, you can safely upgrade the hot end and keep the same firmware.
    Beg your pardon, temperature sensor.
    Thank you both for the advice - as you'll see in the aforementioned thread, the firmware issue is sorted.
    Cheers,
    Matt.
