I also second this request :-)
Unfortunately it's an 15.x plugin...
On the short run you could just manually insert a T1 in the header of the gcode, but to make this plugin working again would be great...
@DaHai8, is there any chance that you could assist?
DaHai8 73
If its a Cura 15.x version plugin, it would have to be rewritten in order to work in Cura 2.x
If its a Cura 2.x version plugin, it probably just needs to minor changes to make it compatible with Cura 2.5.
Edited by GuestLink to post
