Ultimaker 3 heater error on the print head slot 1 ER15.
Posted
· Ultimaker 3 heater error on the print head slot 1 ER15.
There is no such thing as a reliable 3d printer whether you spend $300, $3000, or $300K. I mean it takes some learning and things can go wrong. But the UM3 is much better than most in it's price range. It's more like owning a cnc milling machine than owning a 2D printer as far as "plug and play".
heater error is worrying. It may be a bad core. The easy thing to try is to mark that core as "bad" and try the other AA core instead. Of course you will now have to recalibrate this new combination of cores.
If you are handy and have a multimeter I would ohm out the heater on the core when it's not installed. It should be almost exactly 23 ohms. If you find it is instead closer to say 30 ohms then there is probably a bad connection or a bad heater. I would also try gently tugging on those wires where they connect to the PCB to see if they are loose and to see if the resistance changes when you do that.
Clogging can happen. What material were you printing that clogged? ABS clogs quite easily. Or if you have a lot of dust on the filament the dust can travel slowly with the filament through the tube and into the nozzle where it clogs. If you have a dusty environment you might want to build a filter out of a kleenex and some oil and some string that cleans the filament as it enters the feeder.
You should read about "cold pulls for um3" to get that nozzle unclogged. If it's an ABS then things may be tricky. If you destroy it then this might be a good time to trade it in and upgrade to a hardcore which can take multiple nozzle sizes (full disclosure - I sell those so I'm biased).
1
gr5 2,210
