I'm sorry your message got burried for a day in among thousands of spams. You are now an approved poster and next time it will show up immediately.
fbrc8-erin 267
If you've got the latest firmware on your UM3 there is an option when you pause it to change the material. It's not going to automatically detect for you when the material runs out, you'd have to judge it and change it before you ran out, but it's now in the menu as of 3.6.
1
gr5 2,069
There is a white lever on the feeder. If you squeeze that hard you can just slide filament in and out. So slide out the old and slide in the new. Slide in the new hard enough to make sure you see some filament coming out of the nozzle faster than before you slid it in. I recommend cutting the tip to a point of the new filament first.
