I don't ship to brazil sorry but I don't sell filament or printers either. So the bed? The bed went to 100C? That's the correct temperature for ABS. Maybe you told the UM2 you had ABS? Or maybe Cura tried to set it to 100C.
Well when you start the print and it is heating up the bed (only heats the bed initially) then go immediately to TUNE menu and see what the goal temperature is. You can fix it there. But even better in Materials menu tell it that you currently have PLA in your machine.
1
fergazz 60
@gr5 do you have it in your store? Do you ship to Brazil? If possible I would like to get other stuffs, like olsson block, metal nozzles, slipery bowder tube and others upgrades.
The event was realised at consul's house, there was an electrical outlet with 220V and I asked for an employee of the house if there was a 110V electrical outlet, so the employee point me for another one close to this. Should this issue can be caused by higher voltage? Is UM2 bi-volt?
Edited by Guestvoltage paragraph
