What you can do is print the supports with PLA, and only the support interfaces with PVA.
Support interfaces are roofs and bottoms on either side of the support structure touching the print. Printing supports with PLA and support interfaces with PVA will result in small solluble bits between the supports and the model that should remove cleanly.
Use the small looking glass icon next to custom and type in "interface". Set the "Support Extruder" to Extruder 1, check "Enable support interface" and set the "Support Interface Extruder" to Extruder 2.
1
Nicolinux 288
I don't think that's possible. For the Ultimaker 3 you have a special print core (BB) that's designated for PVA. If the firmware would support it, you could:
Pause print, switch print core from AA to BB, resume print, pause again, switch print core from BB to AA
But frankly, this is more hassle than it is worth it so I doubt this feature would be implemented.
Alternatively you could try to print PLA on the BB core, but since it was not made for that, I don't know how well it will turn out (or if it is even possible - please don't break your print core...)
