kmanstudios 1,117
As dorky as it sounds, try to clean the back connectors with Isopropyl alcohol. I like to use 99% pure to cut down on contaminants.
I switched a BB core out with an AA core and then back again and I must have touched those tiny, delicate contact points in the back and it would not make the adjustment. Cleaned it with the alcohol and it worked again.
I now make sure that I do not touch that area, but it is good to clean every now and then as air pollutants (Dust, moisture, etc) will eventually crud it up a bit.
tomnagel 90
That is annoying indeed. Your printcore might be wrongly programmed. Please contact your reseller.
Edited by GuestLink to post
