To adjust the settings, if you change your mind or think of something, you have to ungroup (In the Edit drop down) and then make your change(s). Then you go back and merge them again.
No need to ungroup. You can also Ctrl-click (or Command-click) an individual object that is inside a group. Ctrl+Shift-click also works to select multiple objects, even in different groups.
1
kmanstudios 1,120
To align objects as you wish, they need to be adjusted in your 3D package so that they all share a common pivot point.
Once in Cura, load each model part separately. Then click on a part and then, in the tab on the left side, click on the icon that looks like 3 hour glasses.
This is your 'per model' settings. You can select each extruder per model as well as select most other settings that would be found in the custom tab. Speed, support, etc. Remember that most can use the common settings, so be sure that you do not overly replicate the settings.
Once all model parts have their individual settings, then select by holding down shift and clicking on each model, or use CTRL+A (Select all) or use the select all option in the edit drop down. After that, then (with all model parts still selected) go back to the edit drop down and choose "Merge Models". this will align all selected model parts and use the pivot point to align them and then group them.
