Tighten them MUCH harder. If you use a hex driver (like a screwdriver) you should be afraid the tool will break. It should twist slightly. If you use an L shaped tool your fingers should hurt for a few minutes after. REALLY TIGHT. You probably only need to get the 2 on the short belts of the slipping axis - not all 11 pulleys. I can't tell which axis is slipping because you already removed the part from the printer.
There's a very small possibility that your stepper drivers overheat and shut off for a half second occasionally also. But I strongly doubt that. You would likely have issues with the Z axis long before X or Y. This is 98% odds that it's a pulley set-screw.
gr5 2,210
