Nexeo Novamid Nylon 1070 and 1030
Karel1986
Posted · Nexeo Novamid Nylon 1070 and 1030
I've wanted to try out Nylon prints for a while now and today I'm trying out a few samples from Nexeo.
Ultimaker 3 Extended.
Nexeo novamid 1070.
First try:
Kapton tape on bed
Buildplate temperature: 110C
Nozzle temperature: 270C
Print speed 70mm/s
Brim: 7mm
Part warped and them came loose after 10 minutes.
Second try:
Kapton tape on bed
Buildplate temperature: 100C
Print speed 70mm/s
Brim: 20mm
Print still going and looking good!
Looking forward to the final result.
What is you experience with Nylon?
    I like Nylon, the Ultimaker nylon prints pretty easy, It also bonds well with PVA.
    I also tried a sample of the 1030 and found it pretty difficult, even though i had a sealed sample i had serious moisture issues. looking at the specs the 1070 is interesting enough to give a try someday.
    for everyone's information, here's datasheets;
    http://wiki.makerpoint.nl/nexeodatasheets
    and I use this for both PVA and nylon;
    https://www.youmagine.com/designs/drybox-for-pva-ultimaker3
    I find the Ultimaker Nylon to print very easily. I use a slurry of PVA and water using recycled PVA from supports and brims, etc. and not a bit of trouble with plate adhesion or anything like that.
    So far no trouble with it.
    But, another brand has given me more difficulties as it seems to absorb moisture from the air more readily as well as, well....just does not behave as well.
    • 1 month later...
