fbrc8-erin 265
It's an M3 screw, but I echo what ultijaran said. I don't recommend unscrewing the frame panels of your printer...ever. Short of having to replace one of them, everything you ever need to access can be accessed without removing them. Removing any of the frame panels will generally throw your XY axis out of alignment and it will need to be recalibrated. I would definitely go with a door that pops into place, or hangs on a hook over the top.
ultiarjan 1,216
Sure it's m3. But why do you want to screw a door to it when something simple like this closes perfectly....
https://www.youmagine.com/designs/um2-minimalist-front-panel
If you do want to screw be carefully not to overtighten the screws....
