Saving project give strange "error message"
hoegge
Posted · Saving project give strange "error message"
When I save a project I get this error message:
You cannot save this document with extension ".3mf" at the end of the name. The required extension is ".curaproject.3mf"
and then I can choose between "use both" and use "curaproject.3mf"
Cura has automatically given the project a name that ends on ".curaproject.3mf" - so why does it complain and what does it mean?
The resulting filenames depending on what I choose are either:
filename.curaproject.3mf.curaproject.curaproject.3mf
or
filename.curaproject.curaproject.3mf
Seems like Cura tries to be smart but is the opposite ;-)
Why don't Cura just not give it the right filetype?
kr
Morten
    • 2 weeks later...
    I have the same issue, but I read somewhere that they are aware of this and working on it. So just wait for that... and yes, it is annoying ...
    Posted (edited) · Saving project give strange "error message"
    It is fixed, but was just too late for Cura 2.6. I'm afraid you have to wait until Cura 2.7
    Great. Thanks
