What happens when I change the speed during a print..
Posted
· What happens when I change the speed during a print..
On my UM2s the speed of printing increases, and the speed of extrusion changes accordingly (so you get the same filling of the model); but also the speed of traveling increases. It does not change temp.
However, if you make brutal speed changes halfway a print, you will see that in the model: it gives different ringing effects around corners, and if the model is small, the difference in cooling time per layer is also visible. Further, if the speed increases brutally, filament has less time to melt in the nozzle, which will give a higher pressure and less extrusion. This is also visible in the print as a faint horizontal line.
Posted
Thanks, That's exactly what I needed to know..
geert_2 558
cairn 5
