Long part print in ABS
Posted · Long part print in ABS
Hello,
I want to print a 260 mm long part with the size of 7x20 mm on the ground. How could I do this in ABS?
I tried to build it landscape, but it blend from the base and I tried to print it vertical. Than after ca. 150 mm it move on the base and you see some defective areas on the part.
Any ideas how I could fix this?
