Hello Peggy
Yes It works manually and more comes out. I did close it properly but I dont think it works 'automatically' :-(
Hello Peggy
the motor should be doing something right ? So i should check if the little black wheel is turning ?
thanks for your help
'sigh' I wish I could just get this thing to work instead of having wasted a ton of money on something that has never worked properly ...what a disappointment this has been from the beginning
So I am watching the black wheel but this is not doing anything. Could the motor be broken ?
Ive tried to look at what cable goes where but the manual is not idiot prrof in the sense that it does not show the ultimaker I have...
do you maybe now if I can go somewhere to get some help ?
thanks again
Hi, did you throw your printer out of the window yet ? Hope not... is there any progress?
is this manual the right one for you? https://ultimaker.com/en/resources/235-assembly
can you look at this video and try to extrude some material at the end;
peggyb 169
are you able to extrude manually, turn the wooden gear in the back by hand so the plastic runs out smoothly? Did you close the extruder on the back properly, black lever to the bottom? Does the black wheel in the extruder on the back turn freely?
