Possibly the infill showing through to the surface. Try un-checking "Infill before walls" and see if that helps.
This option is un-checked already.
Does it happen with every model or just some? If you look at the layer view in cura, what does it look like? The ridges seem to line up with the little "spikes" on the top, maybe there's something weird going on in the exported model that is causing it?
IRobertI 516
