ultradryan 0 Posted July 6, 2017 in Just bought UM3, Questions about CURA profile. Hi, Just bought a UM3. I deleted and reinstalled latest CURA(just so it wont got mixed up with old profiles with my other printer previously). Now I only got "Fine" for use in profile, is this the normal default setting? What about others? I hv to create them from scratch? :( Share this post Link to post Share on other sites
DidierKlein 635 Posted July 6, 2017 in Just bought UM3, Questions about CURA profile. It all depends on the materials you have set i think. Normally you should have other profiles if you use PLA for example Share this post Link to post Share on other sites
ultradryan 0 Posted July 6, 2017 in Just bought UM3, Questions about CURA profile. It all depends on the materials you have set i think. Normally you should have other profiles if you use PLA for example Yes I remember the same when using CURA before. Now the newly installed CURA somehow only have profile "FINE" on default. and in the settings, no profiles were set at all. I am using ultimaker official PLA material with NFC, it got detected alright, so I think it's not the material causing problem. Usually there are recommended profile for different quality settings... I deleted the files in User/App Data/Cura and reinstall, still the same. So I wondered if the latest CURA default profile setting goes with "fine" and no other profiles. Share this post Link to post Share on other sites
nallath 530 Posted July 7, 2017 in Just bought UM3, Questions about CURA profile. Change the material / nozzle in the second extruder. Cura selects a profile that can be used on both extruders. Share this post Link to post Share on other sites
ultradryan 0 Posted July 7, 2017 in Just bought UM3, Questions about CURA profile. Change the material / nozzle in the second extruder. Cura selects a profile that can be used on both extruders. Ah.. so you saying, i am using different filaments on 2 extruders, so it restricts the profile i can choose from? Share this post Link to post Share on other sites
tomnagel 79 Posted July 8, 2017 in Just bought UM3, Questions about CURA profile. If you select 0.4mm nozzle for extruder 1, and 0.8mm for extruder 2, you can only select the 0.2mm profile. Because that is the only profile available to both. With 2 different materials selected for your 2 extruder as it probably works the same (not entirely sure). But since all default materials have (almost) all profiles I think that cannot explain the behavior you see. Share this post Link to post Share on other sites
ultradryan 0 Posted July 8, 2017 in Just bought UM3, Questions about CURA profile. If you select 0.4mm nozzle for extruder 1, and 0.8mm for extruder 2, you can only select the 0.2mm profile. Because that is the only profile available to both. With 2 different materials selected for your 2 extruder as it probably works the same (not entirely sure). But since all default materials have (almost) all profiles I think that cannot explain the behavior you see. I might need to do a reinstall soon just to be sure. But I m hving 2 nozzles the same size. CURA doesnt allow me to create a new profile, the button "create" is grayed out in the "manage profile" settings. That's why I am feeling strange. delete everything in C://User/App Data/local/CURA and reinstall should make a clean installation right? I will try it again. Share this post Link to post Share on other sites
