Thanks for the reply RudydG
I already have an olsson block, and customized cooling fans. So when I buy a feeder I'm done with it?
Can I just update the firmware via cura to ultimaker2+?
It depends a little on the feeder you buy, but basically: yes on both questions. If it does not work, you can also easily flash an ultimaker2 firmware back. And finally, you can also tell Cura you have an Ultimaker 2+ while still using the Ultimaker 2 firmware.
RudydG 62
There is an upgrade kit, you change the extruder + hotend and all the cabling.
Everything is included.
After installing you download the new firmware, and you are on a 2+
No changes to mainboard.
