There's no difference between octoprint on a windows machine and Raspberry pi?
Not much. I would say that getting OctoPrint running on a Raspberry Pi is a bit easier, because there is the dedicated OctoPi images you can flash on an sd card and you're done. I would advise a Raspberry Pi 2 or 3 model over the original or "zero" versions, because the latter are somewhat underpowered.
One tip: in order to print to the UM2+ with OctoPrint, you have to switch the gcode flavor to "Reprap (Marlin/Sprinter)" in the Machine Settings. Otherwise there is no startup code, and the UM2+ will try to start printing without homing or heating up.
- 1
ahoeben 1,968
If I had your problem, I would add a raspberry pi running OctoPrint to each UM2+.
http://octoprint.org/
That way you can send gcode files to the printers over the network, but also control each printer (including pause resume) using a web interface or from inside Cura.
The experience of sending prints to OctoPrint is very similar to sending a print to the UM3.
Turbolego 0
Cool!
I got octoprint installed on the dedicated streaming computer (windows) now (webcam for each UM2+) So i'll try that.
There's no difference between octoprint on a windows machine and Raspberry pi? I got a raspberry pi available if needed.
