Thanks for all the help!
I will try re-leveling to see if the problem persists and I will run a few testes to see how my skirt is printed.
I just dont think I have the motor skills to level the bed while the print is going on...maybe in a few years time ahahaha.
gr5 2,243
It's time to re-level your bed I suspect. I now do it before every print and if it hasn't moved it's trivial. But the bed tends to droop over time. Especially the front edge.
Even if I *do* level I still watch while the skirt is printed - screwdriver in hand - and sometimes make tiny adjustments while it prints the skirt.
A good skirt should be smooth and flat on top. If there is too much space the filament comes out shaped like a tube or string and doesn't stick well. If there is too little space - well on blue tape it can come out like above where there are spots with zero filament and spots with blobs coming out. On flatter surfaces (glass, kaptop tape, aluminum) it basically just doesn't come out or is so thin it's barely visible.
