"Starting..." usually means the loading hangs at the load of the model file. Does this happen at every file or a specific file?
Where can I find the Cura log file? I am on a Mac.
And yes, it is happening on every file now.
Scratch that. It just worked on a file.
It appears to be a network issue because it is not working on files that are in a shared directory.
gr5 1,843
Post the cura log file please. Daid might reply if you do that. Or there might be hints in there.
