I have never changed jerking or acceleration settings, so I can't comment on that. But generally, printing slower (and thus also cooler) greatly reduces this effect: for small high quality parts I use 20 or 30mm/s instead of 50mm/s.
Also, some materials hide this better than others, if they are slightly translucent. But not too translucent, because then you start to see the inner print lines too much.
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
geert_2 557
