Unless you know what you are doing, sketchup produces stl files that are unsuitable for 3d printing. Use another application, such as TinkerCAD.
Thanks I've fixed it now! I assumed that it would figure out boxes drawn on top of boxes, but maybe not. I went inside the model and deleted every internal face, and then deleted every line on the model that wasn't an edge line. It now shows up perfectly in Cura
Thanks :)I've fixed it now! I assumed that it would figure out boxes drawn on top of boxes, but maybe not. I went inside the model and deleted every internal face, and then deleted every line on the model that wasn't an edge line. It now shows up perfectly in Cura
Get the 'Solid Inspector' plugin from the Sketchup Warehouse. It's free and pretty good (not perfect) at checking your models for errors: reversed faces, Stray Edges, Surface Borders, Internal Faces, etc. Save's a lot of time.
- 1
- 4 weeks later...
Have you tried the new Mammoth repair technology in MakePrintable, it should do the job, you can find it under the labs section.
gr5 2,243
Keep cura xray open in one window and sketchup in a second window. Zoom in using the cura zoom controls (plus key on keypad) and drag (shift right click drag) to find the problem face. You have internal walls. If you build a cube with 6 sides. Then add a second cube to the first cube by adding 5 more walls (4 sides and an end) now you have this internal wall that is impossible to print. It is an infinitely thin wall *inside* the model.
STL files don't have "insides" and "outsides". They just have a randomly ordered set of triangles and cura intersects these with a plane to get random line segments. Cura than tries to link these lines up into loops but has trouble with this internal wall which is now an extra line segment confusing cura.
Here is a visual guide to how to clean up sketchup models:
https://i.materialise.com/blog/3d-printing-with-sketchup/
