nullsibnelf 2 Posted August 6, 2017 in Marlin1.1 - Printing time elapsed Hi I flashed Marlin1.1 by today. Printed a benchy. My UMO+ showed following in the display: It took 2hour and a bit. So I think, there is a mistake by hours minuts and seconds in the display. Anybody know, where to fix this? Thanks! Share this post Link to post Share on other sites
DaHai8 67 Posted August 8, 2017 in Marlin1.1 - Printing time elapsed Same as your previous post on Stepper Motor startups: Sounds like a bug in Marlin 1.1 - especially if it didn't happen with the older release. You could try upgrading again to the latest release: 1.1.4 Also check on the Marlin Firmware Forum if its been reported as an issue: http://forums.reprap.org/list.php?415 Share this post Link to post Share on other sites
nullsibnelf 2 Posted August 8, 2017 in Marlin1.1 - Printing time elapsed My fault - the zipfile is named Marlin1.1 but it's 1.1.4 So the is no new version to upgrade Share this post Link to post Share on other sites
drayson 62 Posted August 8, 2017 in Marlin1.1 - Printing time elapsed (edited) Hey, just an advice from the bottom of my heart as I also already spend a few hours with Marlin 1.1.4: Kick it... Go back to the version delivered with your UMO+ and be happy. The new Marlin versions are completely reworked from the status quo Ultimaker branched their version. The old one is stable, the new one is just a collection of features not really necessary. But just for my interest - what's the reason you'd like to change the FW?? Again, just my 2 cents, but you won't be happy with this crap on your UMO... trust me, I know what I'm saying... Edited August 8, 2017 by Guest Share this post Link to post Share on other sites
nullsibnelf 2 Posted August 8, 2017 in Marlin1.1 - Printing time elapsed Hey, just an advice from the bottom of my heart as I also already spend a few hours with Marlin 1.1.4: Kick it... Go back to the version delivered with your UMO+ and be happy. The new Marlin versions are completely reworked from the status quo Ultimaker branched their version. The old one is stable, the new one is just a collection of features not really necessary. But just for my interest - what's the reason you'd like to change the FW?? Again, just my 2 cents, but you won't be happy with this crap on your UMO... trust me, I know what I'm saying... I have to - because of dual extruder update. Share this post Link to post Share on other sites
drayson 62 Posted August 8, 2017 in Marlin1.1 - Printing time elapsed (edited) In this case I would highly recommend using the fork from Ultimaker Marlin or - easier - the one from amedee. He put everything in a nice generator and it works perfect. Try this generator https://bultimaker.bulles.eu/ or this FW from Github: https://github.com/AmedeeBulle/Marlin Edited August 8, 2017 by Guest Share this post Link to post Share on other sites
nullsibnelf 2 Posted August 8, 2017 in Marlin1.1 - Printing time elapsed In this case I would highly recommend using the fork from Ultimaker Marlin or - easier - the one from amedee. He put everything in a nice generator and it works perfect. Try this generator https://bultimaker.bulles.eu/ or this FW from Github: https://github.com/AmedeeBulle/Marlin this one i tried already - and is not working for my setup (40W heaters) Share this post Link to post Share on other sites
drayson 62 Posted August 8, 2017 in Marlin1.1 - Printing time elapsed (edited) Normally it shouldn make a difference in the setup, the only difference is the PID tuning for the stronger heaters. To compensate this it'S necessary to run PID autotune first, note the values and change them in configuration.h. Then flash the updated FW. This you need to do anyway if heaters are changed - no matter which fork you use. I would recommend to use the github version, modify configuration.h according to your setup, setup PID autotune, compile, flash and run .... After this procedure and update of the PID values, everything should work... Edited August 8, 2017 by Guest Share this post Link to post Share on other sites
drayson 62 Posted August 8, 2017 in Marlin1.1 - Printing time elapsed (edited) Ev. hilft das... https://www.bastelbunker.de/marlin-pid-autotuning-fuer-3d-drucker/ or http://www.3deee.ch/?p=508 Edited August 8, 2017 by Guest Share this post Link to post Share on other sites
nullsibnelf 2 Posted August 8, 2017 in Marlin1.1 - Printing time elapsed I've been all this through. read here: https://ultimaker.com/en/community/50569-trouble-with-umo-upgrade Unfortunatly I had trouble with some setting not implemented in that old branch - so i decided to go to the newest. The printer is running quite weell - but there is a bug with the elapsed print-time timer. And that is the topic of this thread. so please - focus on that. Share this post Link to post Share on other sites
drayson 62 Posted August 8, 2017 in Marlin1.1 - Printing time elapsed ok, in this case you could report a bug or ask for support at the Marlin Git... https://github.com/MarlinFirmware/Marlin Share this post Link to post Share on other sites
