@Amedee did this mod so he might help you if has time
About UMO. It works with 19V so there's no real perfect option to use. I assume that the 24V heater should work just fine, mind that it might heat slower? (this I don't know). I know that the 19V heater of UMO does work on a UMO+ 24V board. But I don't know how a 24V heater works on a umo 19V board.
You could also change a component on the umo board to change it to 24V I think. But ofc that might be more mods than what you where planning.
Also you would have to check that the 24V cooling fan works on the 19V fan output of the umo board. That I suppose it's almost the same, it might just work slower? I really don't know since I only have um2.1.x boards.
Yes indeed, I also have an UMO with HBK and I installed an E3D hot end.
You definitely need the 24v version.
I initially mounted it "as such", so it gets 19v. It works fine, even for high temperatures -- I printed PC at 280°C in this configuration -- but it is does not warm up as fast as with 24v. If you consider using the Volcano 19v is probably not enough.
You can easily by-pass the 19v step down and use 24v directly, I recently posted an howto for that.
Re the mount there are plenty available, I posted my own as well.
Thanks for the info, very much appreciated! Ill check out your how to for the bypass.
neotko 1,417
amedee 349
greens83 5
amedee 349
I posted the initial answer from my tablet, not ideal for pasting the links, but here they are:
- 24v : https://ultimaker.com/en/community/44825-24v-for-umo-with-hbk
- My E3d mount : https://ultimaker.com/en/community/35578-yet-another-e3d-v6-mount-for-umo (dual fan setup at the end of that post)
