Dim3nsioneer 557
Maybe some facets with a wrong surface normal? What software was the object made with?
You may try to run your stl file through netfabb online repair service. Maybe it looks different afterwards even in Cura?
Edited by GuestIn 2.7 it is better, but there are other defects showing:
And do those other defects go away when you disable wall overlap compensation?
burtoogle 514
Hi, that looks to me like what you sometimes get when compensate wall overlaps is enabled. In certain situations, I believe that the wall overlap compensation is over aggressive (that is currently being investigated).
Also, there was an issue with the layer view whereby the wrong line width is sometimes used and that was causing line width errors in the layer view that don't actually appear when printed. The line width errors are most obvious when the overlap compensation is enabled because that frigs with the line widths! That layer view issue has been fixed and I believe that the fix is in 2.7.
