GregValiant 1,251
I have seen this problem but it has been a rare occurrence (and hasn't happened lately). I chalked it up to the material I was printing with but I have no idea if that was true, or if it was something Cura was doing to cause it, or my printer was just having a bad day.
This same issue has been commented on here, Github and over on Reddit. I'm sure the developers have seen it discussed. I know I can't duplicate it on purpose (and I have tried) and if the Cura team can't duplicate it then it's near impossible to figure out where in the code there might be a problem.
I can do a close analysis of a gcode file that has the problem. If you would post a gcode file and a photo or screen shot showing where on the model the problem is occurring - I have some tricks to check things like the distance between the extrusions and the amount of flow of those extrusions. If it is a small model and has a single hole in it that would be best. I would bother to throw some filament at it to see if I can duplicate the issue.
esopalumpa 8
I’m pessimistic about this. This is a long lasting problem and until now, I haven’t seen any effort to fix it.
