Dim3nsioneer 559
Sounds to me something was not as it should be in the startup sequence in S3D. No hardware error could make the printer skipping the heating of the bed, except a faulty temperature sensor (which shows about 70 deg too much?). But such a faulty temperature sensor would trigger an temp sensor error in the firmware for sure. So nothing to worry about the hardware.
Labern 775
Yes, it is safe. People print with the bed temp over 100deg all the time for materials like PC.
I have printed a lot with UM Nylon and the default bed temp.
What issues are you having with your print?
Pictures?
