Software stuck
Blopipe
Posted · Software stuck
Please provide some more details.
Does Cura think the printer is in an active print job and you cannot pause or abort from within Cura?
Or do you try to use this from the printer Tune menu?
It's not clear what your current problem is.
    I've had the exact same issue, it constantly thinks the printer is busy, even though it's not.
        • 26 replies
