Posted · usb printing - first layer weirdness
Hi
I am trying to print to my Anet A8 via Cura USB (2.7.0) but I am getting strange results on the first layer. If I save the file and print from memory card it is 100% Apart from the first layer the rest of the print is ok. The results dont seem to change much if I use brim or not.
Any suggestions would be welcome.
Thanks
Tim
    It seems to be getting random read errors on your card. I've seen this before. Occasionally an X or Y value is set to zero or 1 meter or something and the head moves up to the edge of the build.
    It can be caused by:
    10 dust/dirt where memory card touches the contacts. This has happened to me and I fixed with a vacuum cleaner and some q-tips with alcohol.
    2) bad memory card - try a different one
    3) cable cross talk. Try moving the ribbon cables farther from each other and farther from any other electric signals. Just a few mm farther is enough.
    #2 is the easiest to test for. #1 is the most likely.
    Hi
    I am still battling with this, I installed RepetierHost 1.0.5 and that prints fine via usb but I always get a weird first layer with Cura 2.7.0 via USB
    Please help!!!
    Tim
    Most likely your printer does some additional steps, if the print is started from the sdcard (homing, bed leveling? whatever...). I doubt that this can be changed with a specific setting in Cura. But perhaps it's possible with a suitable start gcode script. Is the printer definition for Cura made by yourself? Can you ask the manufacturer of the printer?
    Its a Prusa I3 clone so i am using that profile. There are lots of these out there so I figured I was doing something wrong. Thanks for the suggestion, I will try supplier.
