UM2: Brim adheres but first layer doesn't
some-printer
Posted · UM2: Brim adheres but first layer doesn't
Hello,
I had been using UM2 without issue for a few months.
However a problem has developed where:
  1. The Brim always prints really nicely and adheres to the plate very well (actually it is hard to remove);
  2. But the first layer does not adhere to the plate. Instead it then accumulates onto the hot end as the extruder passes back over the material. So all I get are blobs of plastic mess where the actual layers are meant to be.
I always clean the plate and apply the glue stick before a print.
I have re-leveled the bed.
I am at a loss as how to get this machine to print anything now.
Any advice or help?
    Hi
    Two possibilities come to mind.
    1. You have chosen a very thin first layer in Cura.
    Check that your first layer is 0.3 mm.
    2. The bed is level but at the wrong height. Personally I find that the calibration card Ultimaker supply is too thick. I always need to have the bed leveled closer than this to get a good first layer.
    I once obtained a "Leveling Rings" gcode file that someone made for leveling the bed. This works very well.
    Link here: https://ultimaker.com/en/community/6951-calibration-utility-leveling-ringsgcode
    Hi prb4,
    Thank you for your post and advice.
    I have the first layer set to 0.3mm. I also tried setting it to 0.4mm but it didn't make a difference.
    I tried leveling a few times - using a sheet of paper as the calibration card has been lost. Would you suggest getting the bed leveled closer still?
    I will try the "Leveling Rings" gcode when I get back to the office where the printer is. Thanks for the link!
    Regards,
