Posted · Filament does not attach to the record.
Hei.
I'm trying to run Ultimaker robot for the first time on our Ultimaker 2 Extended + 3D printer. But Filament does not attach to the record? What am I doing wrong? Is Ultimaker Robot set with the settings that should be? Or may I fine tune the settings myself?
Need help! :-)
    First you see this video and calibrate the platform.
    And look heated bed setting,
    PLA Heatedbed=60 Degree
    ABS Heatedbed= 80-100 Degree
    The machine is on the balcony, under the air conditioner, and in front of from the door and window, take him away.
    And I think you should use glue. (This glue UHU Glue Stick. Dont try faber castell, and pritt(it does not work).
    And try this G-Code
    https://drive.google.com/open?id=0B89YxIIGvHVabEFlNkxHY21rbGM
